6sbtixjo
Junior Member level 1
I am designing a 2 stage Miller compensated OTA. I have problem in fixing the output common mode voltage. There was no problem when i designed a differential output OTA, as a CMFB loop ensured proper output DC voltage. But when i tried to design a single ended OTA, i dont get the desired common mode voltage. The first stage common mode output voltage i got was correct as per my design, but the second stage output common mode voltage i get is 10 mV, while i require a 0.9V output common mode voltage. Is there a way to properly fix the output common mode voltage?
