Jun 26, 2008 #1 hkBattousai Advanced Member level 4 Joined Jun 16, 2007 Messages 118 Helped 5 Reputation 10 Reaction score 1 Trophy points 1,298 Location Turkey Activity points 2,182 What capacitor value should I choose for a 48MHz crystal frequency. The datasheet of the PIC only lists capacitor values up to 20MHz as follows : XT Mode : 4 MHz --> 27 pF HS Mode : 4 MHz --> 27 pF 8 MHz --> 22 pF 20 MHz --> 15 pF Click to expand... What are the XT and HS modes here?
Jun 26, 2008 #2 R revlis Junior Member level 1 Joined Jul 16, 2001 Messages 18 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 73 If the 48Mhz crystal is for USB functionality then keep in mind that it has a high precision PLL for the USB Clock which can be driven using a 4Mhz crystal. Check out the PLL section on the data sheet. a USB example @ 20Mhz .
Jun 26, 2008 #3 blueroomelectronics Advanced Member level 5 Joined Sep 17, 2006 Messages 1,681 Helped 180 Reputation 358 Reaction score 77 Trophy points 1,328 Location Toronto, Canada Activity points 8,696 I don't think a 48MHz external crystal is supported, use 20 and the PLL to get the 96MHz USB clock
Jun 26, 2008 #4 Y ywzslm Newbie level 6 Joined May 1, 2007 Messages 14 Helped 1 Reputation 2 Reaction score 0 Trophy points 1,281 Location bulgaria Activity points 1,337 in the book type of Oscillator frequency RC 0 – 4 MHz LP 5 – 200 KHz XT 100 KHz – 4 MHz HS (-04) 4 MHz HS (-10) 4 – 10 MHz HS (-20) 4 – 20 MHz the maximum is 20Mhz
