Brandon Yau
Newbie level 6
- Joined
- Mar 9, 2015
- Messages
- 12
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 88
Hi everyone,
In the first picture, the circuit does not work when it is connected to the sbreak switch.
In the second picture, the circuit works when it is connected to the gate driver (E) and the mosfet (IRF150), but the result goes wrong.
I connected the upper dual flyback circuit and the lower compensated error amplifier+PWM circuit following the specs, the result should be correct. When I just construct the simple dual flyback circuit, the result is correct and works well with the sbreak switch. When everything is connected together, the sbreak switch fails.
Whats wrong with it?
