I tried that, but I didn't find anything useful for placing on the bottom... I'm using OrCAD 9.2. :?:
I think it was a key shortcut? I'll keep trying... thanks.
If u are working in the orcad10.5 layout plus tool den select the component and press 1 for Top layer and 2 for Bottom layer.After that place in the corresponding layer,or select the component and right click den see is there any options like mirror or double click the comp., and check is there any options to mirror the components
select the component ,it will attach to the cursor and then right click select Opposite (T) from the pop up menu,the component will get mirrored then place it.
yes majnoon is right you slect the component by left click than either press T or right click and in the options you will see "opposite" command.
these commands are for Orcad 9.2 and I think will work in any version of Orcad.
