Electro nS
Full Member level 6
- Joined
- Mar 9, 2013
- Messages
- 324
- Helped
- 49
- Reputation
- 98
- Reaction score
- 48
- Trophy points
- 1,308
- Activity points
- 3,818
hi guys ,
just thinking , when and why it is necessary to use optoisolation in DC (mosfet) motor controllers ?
is it when using high voltages only ? or is it feasable / necessary on voltage from 12-36v ??
and lastly how much isolation is required do i have to use optoisolated gate drivers + isolated supply + separate battery for logic ??
if i use the same battery to operate the high current section and use a dc-dc isolated module to get the logic and driver supply and i use the IR21844 IC which seems to have separate Vss (logic GND) and Com (return source). is this a good /enough ??
any help is appreciated
thanks
thanks
