Optimal threshold determination method
Threshold voltages , you get theoretical and also by performing simulations.
You can perform the simulations on required device and check when it switches on.
If the device, you are looking for is MOSFET, Theoretical calculation of threshold voltage is given here:
You can find theoretical derivation of particular device in respective books.
Let me know , if you have more queries.
Also,Please provide some more info about the device you are referring to and parameters of the same.
To identify the set of digitally modulated signals, parameters such as mean, moment, cummulants are extracted from information of signal. By comparing the parameter value of the signal with a certain threshold, the digitally modulated signal is identified. So in this context, I need few ideas on how to determine thresholds of these parameters.
