Opnet does not have a compiler. You have to install compilers like VC++ or visual studio 2005 or anyother version. Then you have to change the environment variable of your computer. It will be in properties of your MyComputer
On Windows NT:
Start -> Settings -> Control Panel -> System -> Environment
On Windows 2000 and Win XP:
Start -> Settings -> Control Panel -> System -> Advanced -> Environment Variables
Each time a variable is updated, you need to click the Set button for the changes to take effect. Once all of the changes have been made, click OK to close the dialog box.
Note that for some systems, the 8.3 format must be used in order to see proper behavior (e.g. "C:\PROGRA~1\MICROS~1\Common\Tools"). Note also that spaces should not be used immediately after the semicolon (";") character in the environment settings. for further help in setting system environment variables, contact your system administrator.
THE FOLLOWING INSTRUCTIONS ARE FOR Windows NT, Windows 2000 and Win XP:
************* IMPORTANT NOTE *****************
For all of the environment variables below, do not put spaces between the directories.
There should be NO SPACE between the semicolon ";" and the drive letter of the next directory!
For example, the following is CORRECT:
C:\Program Files\Microsoft Visual Studio\Common\msdev98\BIN;C:\Program Files\Microsoft Visual Studio\VC98\BIN;
However, the following is INCORRECT:
C:\Program Files\Microsoft Visual Studio\Common\msdev98\BIN; C:\Program Files\Microsoft Visual Studio\VC98\BIN;
Add the following items to the PATH environment variable.
C:\Program Files\Microsoft Visual Studio\Common\TOOLS\WINNT;
C:\Program Files\Microsoft Visual Studio\Common\TOOLS;
Add the following items to the INCLUDE environment variable.
C:\Program Files\Microsoft Visual Studio\VC98\ATL\INCLUDE;
C:\Program Files\Microsoft Visual Studio\VC98\INCLUDE;
C:\Program Files\Microsoft Visual Studio\VC98\MFC\INCLUDE;
Add the following items to the LIB environment variable.
C:\Program Files\Microsoft Visual Studio\VC98\LIB;
C:\Program Files\Microsoft Visual Studio\VC98\MFC\LIB;
Add the following item to the MSDevDir environment variable.
C:\Program Files\Microsoft Visual Studio\Common\MSDev98
Note: These instructions assume MSVC was installed in the default location.
If MSVC was installed in a different location on your system you may need to
modify the paths specified above to match your installation.
TO VERIFY THAT THESE SETTINGS ARE CORRECT:
One quick way is to open a new OPNET Console (from the "Start" button, select "Program Files"->"OPNET Modeler" -> "OPNET Console") then type the following and examine the output of "path", "lib" and "include" environment variables.
prompt> set
Another way to check, is to type the following command:
prompt> cl
If it returns the following output:
Microsoft (R) 32-bit C/C++ Standard Compiler Version 12.00.8168 for 80x86
Copyright (C) Microsoft Corp 1984-1998. All rights reserved.
usage: cl [ option... ] filename... [ /link linkoption... ]
Then it means that MSVC++ is in your path.
Note: If the instructions in this FAQ do not appear to succeed, in certain very rare cases, it has been reported that the issues may be fixed by using tildes ('~') in the above paths to achieve 8.3 format such as:
C:\PROGRA~1\MICROS~1\Common\MSDev98
If you continue to experience issues, you may also wish to see the paths used by MS Visual C++ by examining the file:
C:\Program Files\Microsoft Visual Studio\VC98\BIN\VCVARS32.bat
