> - I intend to choose among GUI Lib and easyGUI
> (https://www.easygui.com) library, could You write about advantages
> of your GUI Lib
It is mostly a matter of taste. The choice should depend on how
you would like to work, now and in the future.
Their design is based on a larger core which interpret C tables.
As these tables can be rather complex your GUI code will to a high
degree be limited to the features provided by their setup tool,
both now and during future maintenance.
Our libraries are based on function calls and therefore scaleable
with the requirement of the application. The designer is free to
create and use any GUI "style" most optimal for the give embedded
application area.
