it simply doesn´t matter. If the vector is in one direction then probably the sign of the value is negative...
According this picture: (assuming the bottom line is GND and all voltages are referenced to GND)
V+ is positive
IC+ is positive
(multiply both and get "positve" power, which means the OPAMP consumes power)
V- is negative
IC- is negative
Io is positive and negative
Ip, In will be close to zero and may be positive as well as negative.
It´s all a question of "point of view".
Klaus
