djolestojic
Member level 5
I have the problem concerning running dsPIC microcontroller with CCS PCHWD compiler. Namely, I cannot make it run with the maximum speed, by issuing the appropritate PLL command (FUSE).
I, also, tried with #USE delay command but the end result was always the same: the microcontroller operated with 2.5 MHz clock.
Is there any way to solve this problem?
Thanks
Thanks
