Open loop transfer simulation
Humungus
Full Member level 6
Full Member level 6
I have to simulate the open loop gain of a differential ampllifier (to get ft and phase margin) at several temperatures and DC input levels.
What I normally do is to put the amplifier in closed loop, in the non-inverting input I apply the DC level that I want and I make a DC simulation at a given temperature. Then, I got the output DC level that make my amplifier is within the linear region. I apply that DC level to the inverting input and do the AC simulation.
The diff. amplifier I'm trying to simulate has high gain (more than 100dB), so, if I don't set both inputs at the right value, the smallest offset (random or systematic) makes my amplifier to saturate.
In some cases one can calculate the open loop gain by putting the amplifier in closed loop and defining the open loop gain as
Vout/(Vin_plus - Vin_minus). This is usefull for relatively low gains, as the gain increases the error introduced by the numerical calculations done by the simulator increases too.
Also I must do Monte Carlo analysis at several DC input levels and several temperatures.
What's the most efficient way to automatize the simulation procedure?
I'll apreciate very much any help
Regards
Hi Humungus,
for simulation purpose put an inductor between output an inverting input with 1THenry. Then for DC it compensates your minimal errors and for AC it is like NC.
And certainly tie it to ground with a resistor.
The only thing you have to do is to divide output spectrum through input spectrum.
hope it helps,
Aoxomox
Hi, thanks for your reply
I actually used an LC cell. The inductor, as you said, between the output and inverting input and the C to tie the inverting input to ground at AC.
Thanks again
