open loop dc motor control
seyyah
Advanced Member level 2
open loop motor control
In an open loop pwm control of a dc motor what makes the starting torque be enough for the load to begin its movement?
For example which choice is good for this purpose
1000 rpm 24V 300W motor? or
1400 rpm 24V 300W motor? or
1400 rpm 24V 200W motor? or
1000 rpm 24V 200W motor?
I have also choices of using a gear turns ratio of 5 to 10.
I tried 1/10 turns ratio and 200W 1400rpm motor. It has problems at starting and top speed is near enough (it musnt be lower than this speed)
Is 1000rpm 300W motor with a gear ratio of 1/5 helps me?
What other suggestions can you propose?
jamesyang1209
Full Member level 1
static friction in dc motor
I think you got confused about friction, watt and gear ratio.
If your system has no friction, you only need to calculate the gear ratio and motor rpm, you will know the output rpm. You don't need to worry about the Watt of motor.
But, in fact, the friction comes.
So, you need to care about is torque.
I mean, more watt and less rpm motor will give you more torque to overcome the starting friction (static friction).
And, more gear ratio, the more output torque you get. That is, 1/10 will output more torque than 1/5.
Yes, it's hard to calculate, since many variables. And the friction is hard to measure.
I sugged you to check the motor's torque first.
And re-calculate this problem.
Try error is another method.
CMOS
Advanced Member level 3
USA
As far as I know DC motors are generally not controlled in open loop since speed variation due to change in supply voltage is much larger than ac motors. In fact ac motor's speed depend very much on frequency rather than voltage.
jamesyang1209
Full Member level 1
No.
In manufacture, lots of motor controled only in open loop with limit switch.
river78
Member level 1
Hi!
I think the torque of motor depend on power of motor. But in your case, i think u should have an current loop control , i will improve the start torque motor.
Good luck!
ricky_wcy
Junior Member level 3
Agree, in manfacturing, open loop control is used in driving dc motor for limited switches
Any circuit design for such condition ?
Mr.MEB
Member level 3
In process plants DC motors are controlled both in Torque and speed.
Look at paper mills you will see plenty of them.
ricky_wcy
sorry, what is paper mills ?
yangxh
Member level 5
jamesyang1209 said:
No.
you mean PWM?
