I am new in Hardware design .
I have seen Open Drain pin in a controller ,so what does it mean . Can i use it as input or output . how to use it .Some of documents say it should be pull up with a Vcc ,why should be so , if i connect it with GND .
how it high impedance or low impandce being used here .How do Pull up work here .pls elobrate your answer as i am confuse after searching many web sources .
This is called open collector configuration,
If the transistor is switched ON the output will be low...
and if it is turned OFF there is no connection in the output pin that is considered as the high impedance state ((if you connected a pull up it will be now high or vcc)there is no term called low impedance state)...
