[SOLVED] Opamp works fine with DC - but getodd values with AC
kochevnik
Hi all -
I'm a beginner :)
I have an inverting opamp circuit (similar to attached) that is working just fine with DC on the I- pin but when I set up my function generator to output an AC signal of roughly the same voltage P-P the opamp is outputting a similar sinewave, but it's not amplified very much.
The opamp is a MCP6241-E/P with 550khz gain bandwidth product (datasheet attached). I'm powering it with a voltage 5.35 V on Vdd and Vdd/ 2 = 2.66v on I+ and this opamp is supposed to go rail to rail (which it does with DC just fine).
The basic circuit I have is with a 1 M ohm resistor from Vout to I- and then I have a bunch of different resistors I try on Vin 800k 467k 325k 200k etc this lets me easily watch the change on Vout as I change the gain. This all works great with DC - I get almost the exact right voltages on Vout that would be predicted from the opamp formulas.
So now I hook up a 150khz - not quite a clean sine wave - from my signal generator but fairly close, then I use the EXACT same setup, only adding a 4u7 cap on Vin (I was under the impression this is a DC blocking cap) and then check Vin and Vout on my scope while I change the resistor values on Vin (same values I have listed above).
The output is a nice clean sinewave, but the peak to peak voltage does not vary much (5% maybe) as I try the different resistor combinations.
For example - my not so clean sine wave going into Vin is 0.285v P2P and on Vout I get a nice clean sinewave of 0.530 volts P2P - for ALL of the different resistor combos above. I switch them and I get some small changes in Vout, but nothing like the changes I got with the DC testing.
And a few odd things - If I run Vin directly into pin2 without a resistor or cap, I still get a nice sinewave on Vout, only the voltage is now 0.23v P2P not the 0.53 volts I get when I try all the resistors.
So what gives ? What am I doing wrong ?
Thx -k
  • Amplified-Mic-Electret-v14[1].pdf
  • mcp6241 opamp.pdf
150kHz? Your opamp only has 550kHz GBW so you will get very little gain at 150kHz. Your resistors are set to give you a gain of 100 in the diagram. Try a lot lower frequency - say 1kHz.
Keith
Thanks - appreciate the replies - but the circuit is just an example - remember that the test resistors I used were 1M ohm for the feedback resistor and 810k ohms for the resistor on Vin - this gives a gain of -0.810 for an inverting amp.
Or for one of the other resistors I tried (325k ohms) this gives a gain of
-0.325
according to this calculator :
Example :
r1 = 1000
r2 = 810
r3 = 0
r4 = 1
v1 = 0.1425 (1/2 of .285v ?)
v2 = 2.66
Vp = 5.35
Vn = 0
gives a Vout = 4.70v
changing v to 0.285v (?) still gives 4.58v
Neither of these is close to what I actually saw on the scope.
I think I got the answer to this - figure 2-15 in the spec sheet for the opamp shows the max output voltage swing and it is limited @ 150khz.
Thx keith for your help.
Solved.
I was just going to say that you will be slew rate limited so while you could get a small gain at 150kHz, that would only be with a small signal.
Keith
Keith
Yes - of course, it is the limited slew rate (0.3V/usec) that is responsible for the problems.
