OPAMP virtual short in feedback
ljy4468
Full Member level 4
South Korea
Hi
I've a question about feedback opamp .
In feedback, inp & inn is same (If open loop gain is infinity)
But Why??
this question may seems to be ridiculous...but I want to know mathmatically....clearly.
anyone gives me help~
Thanks in advance.
some of the book about opamp also introduced
If we have infinite gain ... by
Vo = A ( Vinp-Vinn) then
Vinp- Vinn = Vo / A ..
So, we have
Vin - Vinn ~~ 0 ..
If this is not enough .. let me know
if the voltage gain is finite, virtual short is not corrent.
in fact, if the opamp with feedback work normally, the two input terminal is approximtely virtual short. But if the opamp acts as a comparator, the two terminal is not virtual ground. in short, the phenomenon of vitual short is based on the negative feedback.
hi qutang!
thanks for your answer.
But, In Open loop configuration,
[Vo = A ( Vinp-Vinn) then
Vin - Vinn ~~ 0 .. ]
is also right, isn't it?
what's the difference?
if the voltage gain is not infinit, the two terminal is not virtual ground.
