woodrave
Newbie level 3
op amp integrator design
Hello,
for a school project, we have to design an OpAmp for a switched-capacitor integrator. The goal is to design the OpAmp for the first integrator (see picture) with the following constraints:
-clock frequency: 50 MHz
-3.3V
-Choose Vcm and Vcm,in as good as possible
I'm not looking for someone who gives me a finished circuit, but rather for some directions on how to start.
I already did some research, and found that your GBWP should at least be 10 times fclock, so that would be 500 MHz here. Is that a good choise?
For the voltage Vcm,in , I suspect it to be as low as possible. Depending on the circuit this would be something like 2*Vdsat. And for Vcm: half the Vdd voltage: 1.65 V. This allows a maximal swing.
Furthermore, I'm not sure what the load capacity is for the first integrator. I calculated 4.5 pF, but I'm not sure of that.
And for the topology, I suggest it would be good to use an OTA, since the load is completely capacitive. But I'll probably need a second stage to obtain a good gain...
Can someone tell me if I'm thinking in the good direction here, or is this all completely wrong?
cheers,
Bert
Hello,
-3.3V
cheers,
Bert
