op-amp with gain>60db
elmasso
Newbie level 1
hi i have a homework that want me to design a op-amp with these specs :
single ended output and gain greater than 60db
capacitor load 1pf
Vdd = 3.3v
output swing > 2.4v
ugf>200MHz
Slew Rate > 400v/us
power<6mW
phase margin >60 degrees
it would be great help if someone can help me with design or introduce me some sources ASAP
erikl
Super Moderator
Staff member
Germany
... introduce me some sources
I think it's not impossible, but challenging. You'll need at least 400µA in the output stage(s).
Read chap. 5: Design of CMOS Operational Transconductance Amplifiers Optimized for DC, Balanced, and AC Performance from David M. Binkley's book "Tradeoffs and Optimization in Analog CMOS Design"
tompham
Full Member level 2
usa
Hi elmasso
Use folded cascode with tail current and 2 legs > 400uA you can do it
schmitt trigger
Advanced Member level 5
The question is: is the 1pF load realistic at all?
This is way too low. Almost anything that you put on the output will have at least a few pF.
schmitt trigger
Not, if it is a CMOS gate again, e.g. an output amplifier on the same chip.
You are absolutely correct,
but unfortunately the poster's original requirements left this open to interpretation.
