OP-AMP input overdrive??
niks
Full Member level 3
Full Member level 3
input overdrive
How comparator input overdrive and propagation delay is related ??
flatulent
Advanced Member level 6
Middle Earth
comparator overdrive
Overdrive willmake it a little faster. Most data sheets will show you several examples.
trifilinux
input overdrive op
Hi all,
are you considering an op-amp with internal compensation? if the op-amp input stage is saturated, there is no more dependance on the input signal amplitude due to slew rate limitation and compensation capacitance.
If you consider an open loop or hysteretic circuit designed to work as comparator, it is necessary to see the schematic to provide an answer. If needed, I can provide circuit ideas and topologies.
:roll:
