malli_1729
Full Member level 5
hi!
Here i am a circuit and some text from application note, in which i have doubt.
First one 3 circuits 3.26A , B and C.Next 2 are matters regarding the circuits attached.
in 1.jpg, given as
what is noise gain and How these input offset voltage depend on it.
in 2.jpg, Given as
Generally CM range for an opamp will be fixed and Known from the datasheet.But why here it is given CM range is fixed in B and C and not for A.
one more doubt
signal current flows into/from Vref means current from Vi or Vout which will flow through Vref
I don't know whether i can clear or not...i am brushing my basics...it will be great help to if any body explain these things...
thankQ
in 1.jpg, given as
""Noise gain is increased, due to that sensitivity to input offset voltage and Noise are increased
in 2.jpg, Given as
3.36A is sensitive to impedance of Vref. this is due to signal current flows into/from Vref, due to Vin operating the op amp in its CM Range.where for other circuits CM range is fixed
one more doubt
thankQ
