T
treez
Hello,
Page 4, bottom RHS of page states that the flyback winding width should be at least twice the creepage distance in order to reduce leakage inductance.
http://www.powerint.com/sites/default/files/product-docs/an17.pdf
In mains flybacks in led light bulbs, why not do away with the creepage requirement altogether, and thus reduce transformer leakage further?
After all, enamelled copper wire has 1000VAC of insulation on it. (not talking about triple insulated wire).
After all, some led light bulbs are being made with no creepage built in at all..as follows
....At time 20:52 of the following, is this the proof that bulb is not isolated?....
http://www.youtube.com/watch?v=YLlpoZaBx-g
..also, if you view from time 6:34 of the above video , you can see that the MCPCB that contains the (non-isolated) led circuit is literally lying right on the heatsink which which appears to be opening out to the external of the bulb
