Odd components in these signals
sky_tm
Junior Member level 1
Find the even and odd components for each of the following signals:
i) x(t) = exp^(-2t) sin (2t)
ii) x(t) = 1 + t + t³ + t^5
iii) x(t) = 1 + sin(t) + t cos(t) + t² sin(t) cost(t)
newmin
Re: Signals
Even part of x(t) = 0.5 [ x(t) + x (-t) ]
and
Odd part of x(t) = 0.5 [ x(t) - x (-t) ]
Use those formulas, to find even and odd component of your signals.
For example
(ii) For x (t) = 1 + t + t^3 + t^5,
Even part of x(t) will be 0.5 {[ 1 + t + t^3 + t^5] + [1 + (-t) + (-t)^3 + (-t)^5]} = 1
Odd part of x(t) will be 0.5{[ 1 + t + t^3 + t^5] - [1 + (-t) + (-t)^3 + (-t)^5]} = t + t^3 + t^5
    sky_tm
sky_tm
Signals
Thanks for the part (ii) answer. Can you show part (i) and (iii) as well?
Danie
Re: Signals
Anwers to (i) & (iii)
(i) Even part = 0.5[exp^(-2t) sin (2t) + exp^(2t) sin (-2t)]
Odd part = 0.5[exp^(-2t) sin (2t) - exp^(2t) sin (-2t)]
(iii) Even part = 0.5[{1 + sin(t) + t cos(t) + t² sin(t) cos(t)} + {1 + sin(-t) - t cos(-t) + t² sin(-t) cos(-t)}]
Odd part = 0.5[{1 + sin(t) + t cos(t) + t² sin(t) cos(t)} - {1 + sin(-t) - t cos(-t) + t² sin(-t) cos(-t)}]
where sin(jw) = [exp^(jw) + exp^(-jw)]/2
and cos(jw) = [exp^(jw) - exp^(-jw)]/2
Further Eulers theorem can be used
exp^(jt)= cos(t) + jsin(t)
then they can easily be simplified :D !!!
purnapragna
Full Member level 1
Re: Signals
Note that by looking at the signal itself we can find the even and odd parts of it.
For example
(ii)
\[x(t)=1+t+t^3+t^5\]. In this except \[1\], which is even function, the remaining part \[t+t^3+t^5\] is odd function.
(iii) Same is the case for this too. Note that except
\[1\], which is even function, the remaining part \[\sin(t)+t \cos(t)+t^2 \sin(t)\cos(t)\] is odd function.
(i) For this type of functions we have to evaluate the formulas:
\[x_e(t)=\frac{x(t)+x(-t)}{2}\] and
\[x_o(t)=\frac{x(t)-x(-t)}{2}\].
For problems(ii) and (iii) even after applying these results, we get the same answers. The answers we get above is by inspection.
thnx
purna!
imperial_amazon
Newbie level 3
Newbie level 3
Re: Signals
A further simplification of problem ii would lead to
even part= sin2t * sinh2t
odd part= sin2t * cosh2t
Added after 1 minutes:
sorry.. the above solution i've mentioned is for problem (i)
JoseLeonardo
Full Member level 1
Full Member level 1
Signals
you can read the book, Signals and Systems by Oppenhiem
sky_tm
Re: Signals
Conclusion:
i) \[x_e (t) = - \sin (2t)*\sinh (2t)\]
\[x_o (t) = \sin (2t)*\cosh (2t)\]
ii) \[x_e (t) = 1\]
\[x_o (t) = t + t^3 + t^5\]
iii) \[x_e (t) = 1 + t^2 \sin t\cos t\]
\[x_o (t) = \sin t + t\cos t\]
