Code dot - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 prt=outfile("/home/15vl21f/current_bias.csv" "w") simulator( 'spectre ) design( "/home/15vl21f/simulation/Current_bias/spectre/schematic/netlist/netlist") resultsDir( "/home/15vl21f/simulation/Current_bias/spectre/schematic" ) openResults( "/home/15vl21f/simulation/Current_bias/spectre/schematic" ) modelFile( '("/opt/cad/cad/FOUNDRY/analog/180nm/models/spectre/gpdk.scs" "stat") ) analysis('dc ?saveOppoint t ) analysis('ac ?start "10" ?stop "100G" ) fprintf(prt "I, W, L, Gain, Bandwidth, overdrive, tail_current\n") desVar( "I" ) desVar( "W" ) desVar( "L" ) envOption( 'analysisOrder list("dc" "ac") ) temp( 27 ) run() reg_0=pv("NM0" "region" ?result "dcOpInfo") reg_1=pv("NM2" "region" ?result "dcOpInfo") reg_2=pv("PM0" "region" ?result "dcOpInfo") when(((reg_0==2) && (reg_1==2) && (reg_2==2)) x = ymax(db20(VF("/vout"))) y = bandwidth(VF("/vout") 3 "low") vth = pv("NM0" "vth" ?result "dcOpInfo") vgs = pv("NM0" "vgs" ?result "dcOpInfo") overdrive = vgs - vth tail_current = 2 * pv("NM0" "id" ?result "dcOpInfo") Gain = x Bandwidth = y fprintf(prt "%d, %f m, %f m,%f dB, %f Hz, %f V, %f A\n", I, W, L, x, y, overdrive, tail_current) ) ) ) ) close(prt);
prt=outfile("/home/15vl21f/param.csv" "w")
design( "/home/15vl21f/simulation/diff_amp/spectre/schematic/netlist/netlist")
resultsDir( "/home/15vl21f/simulation/diff_amp/spectre/schematic" )
modelFile(
desVar( "W" "" )
desVar( "L" "" )
desVar( "I" "" )
envOption(
temp( 27 )
paramAnalysis("I" ?values '(0.00015 0.00016 0.00017 ) ?sweepType 'paramset
paramAnalysis("W" ?values '(5e-07 8e-07 1e-06 ) ?sweepType 'paramset
paramAnalysis("L" ?values '(1e-05 1.5e-05 2.5e-05 ) ?sweepType 'paramset
paramRun()
fprintf(prt " %f A, %f m, %f m,%f dB, %f Hz\n", I, W, L, x, y)
close(prt);
I doubt that it just says "error".I tried it but i'm getting error.
Usually there is an error description. This description is useful to locate and correct the error.
Therefore it is essential to tell us the complete error description.
Klaus
// Library name: Kiran_OTA
// Cell name: diff_amp
// View name: schematic
NM3 (net5 net5 0 0) nmos1 w=((W) / (1)) l=L as=(((W) / (1)) < 599.5n) ? (((((200n > (((400n) - 200n) + 400n)) ? 200n : (((400n) - 200n) + 400n)) * 600n) + (((W) / (1)) * 200n)) + (floor(((1) - 1) / 2.0) * (((((400n) - 200n) + 400n) * 600n) + (((W) / (1)) * 400n))) + ((((1) / 2) - floor((1) / 2) == 0) ? ((((200n > (((400n) - 200n) + 400n)) ? 200n : (((400n) - 200n) + 400n)) * 600n) + (((W) / (1)) * 200n)) : 0)) / 1 : ((((400n > (((400n) - 200n) + 400n)) ? 400n : (((400n) - 200n) + 400n)) * ((W) / (1))) + (floor(((1) - 1) / 2.0) * ((((400n) - 200n) + 400n) * ((W) / (1)))) + ((((1) / 2) - floor((1) / 2) == 0) ? (((400n > (((400n) - 200n) + 400n)) ? 400n : (((400n) - 200n) + 400n)) * ((W) / (1))) : 0)) / 1 \
ad=(((W) / (1)) < 599.5n) ? ((floor((1) / 2.0) * (((((400n) - 200n) + 400n) * 600n) + (((W) / (1)) * 400n))) + ((((1) / 2) - floor((1) / 2) != 0) ? ((((200n > (((400n) - 200n) + 400n)) ? 200n : (((400n) - 200n) + 400n)) * 600n) + (((W) / (1)) * 200n)) : 0)) / 1 : ((floor((1) / 2.0) * ((((400n) - 200n) + 400n) * ((W) / (1)))) + ((((1) / 2) - floor((1) / 2) != 0) ? (((400n > (((400n) - 200n) + 400n)) ? 400n : (((400n) - 200n) + 400n)) * ((W) / (1))) : 0)) / 1 \
ps=(((W) / (1)) < 599.5n) ? (((2 * ((200n > (((400n) - 200n) + 400n)) ? 200n : (((400n) - 200n) + 400n))) + 1.6u) + (floor(((1) - 1) / 2.0) * ((2 * (((400n) - 200n) + 400n)) + 2u)) + ((((1) / 2) - floor((1) / 2) == 0) ? ((2 * ((200n > (((400n) - 200n) + 400n)) ? 200n : (((400n) - 200n) + 400n))) + 1.6u) : 0)) / 1 : (((2 * ((400n > (((400n) - 200n) + 400n)) ? 400n : (((400n) - 200n) + 400n))) + (2 * ((W) / (1)))) + (floor(((1) - 1) / 2.0) * ((2 * (((400n) - 200n) + 400n)) + (2 * ((W) / (1))))) + ((((1) / 2) - floor((1) / 2) == 0) ? ((2 * ((400n > (((400n) - 200n) + 400n)) ? 400n : (((400n) - 200n) + 400n))) + (2 * ((W) / (1)))) : 0)) / 1 \
pd=(((W) / (1)) < 599.5n) ? ((floor((1) / 2.0) * ((2 * (((400n) - 200n) + 400n)) + 2u)) + ((((1) / 2) - floor((1) / 2) != 0) ? ((2 * ((200n > (((400n) - 200n) + 400n)) ? 200n : (((400n) - 200n) + 400n))) + 1.6u) : 0)) / 1 : ((floor((1) / 2.0) * ((2 * (((400n) - 200n) + 400n)) + (2 * ((W) / (1))))) + ((((1) / 2) - floor((1) / 2) != 0) ? ((2 * ((400n > (((400n) - 200n) + 400n)) ? 400n : (((400n) - 200n) + 400n))) + (2 * ((W) / (1)))) : 0)) / 1 \
m=(1)*(1)
NM2 (net11 net5 0 0) nmos1 w=((2*W) / (1)) l=L as=(((2*W) / (1)) < 599.5n) ? (((((200n > (((400n) - 200n) + 400n)) ? 200n : (((400n) - 200n) + 400n)) * 600n) + (((2*W) / (1)) * 200n)) + (floor(((1) - 1) / 2.0) * (((((400n) - 200n) + 400n) * 600n) + (((2*W) / (1)) * 400n))) + ((((1) / 2) - floor((1) / 2) == 0) ? ((((200n > (((400n) - 200n) + 400n)) ? 200n : (((400n) - 200n) + 400n)) * 600n) + (((2*W) / (1)) * 200n)) : 0)) / 1 : ((((400n > (((400n) - 200n) + 400n)) ? 400n : (((400n) - 200n) + 400n)) * ((2*W) / (1))) + (floor(((1) - 1) / 2.0) * ((((400n) - 200n) + 400n) * ((2*W) / (1)))) + ((((1) / 2) - floor((1) / 2) == 0) ? (((400n > (((400n) - 200n) + 400n)) ? 400n : (((400n) - 200n) + 400n)) * ((2*W) / (1))) : 0)) / 1 \
ad=(((2*W) / (1)) < 599.5n) ? ((floor((1) / 2.0) * (((((400n) - 200n) + 400n) * 600n) + (((2*W) / (1)) * 400n))) + ((((1) / 2) - floor((1) / 2) != 0) ? ((((200n > (((400n) - 200n) + 400n)) ? 200n : (((400n) - 200n) + 400n)) * 600n) + (((2*W) / (1)) * 200n)) : 0)) / 1 : ((floor((1) / 2.0) * ((((400n) - 200n) + 400n) * ((2*W) / (1)))) + ((((1) / 2) - floor((1) / 2) != 0) ? (((400n > (((400n) - 200n) + 400n)) ? 400n : (((400n) - 200n) + 400n)) * ((2*W) / (1))) : 0)) / 1 \
ps=(((2*W) / (1)) < 599.5n) ? (((2 * ((200n > (((400n) - 200n) + 400n)) ? 200n : (((400n) - 200n) + 400n))) + 1.6u) + (floor(((1) - 1) / 2.0) * ((2 * (((400n) - 200n) + 400n)) + 2u)) + ((((1) / 2) - floor((1) / 2) == 0) ? ((2 * ((200n > (((400n) - 200n) + 400n)) ? 200n : (((400n) - 200n) + 400n))) + 1.6u) : 0)) / 1 : (((2 * ((400n > (((400n) - 200n) + 400n)) ? 400n : (((400n) - 200n) + 400n))) + (2 * ((2*W) / (1)))) + (floor(((1) - 1) / 2.0) * ((2 * (((400n) - 200n) + 400n)) + (2 * ((2*W) / (1))))) + ((((1) / 2) - floor((1) / 2) == 0) ? ((2 * ((400n > (((400n) - 200n) + 400n)) ? 400n : (((400n) - 200n) + 400n))) + (2 * ((2*W) / (1)))) : 0)) / 1 \
pd=(((2*W) / (1)) < 599.5n) ? ((floor((1) / 2.0) * ((2 * (((400n) - 200n) + 400n)) + 2u)) + ((((1) / 2) - floor((1) / 2) != 0) ? ((2 * ((200n > (((400n) - 200n) + 400n)) ? 200n : (((400n) - 200n) + 400n))) + 1.6u) : 0)) / 1 : ((floor((1) / 2.0) * ((2 * (((400n) - 200n) + 400n)) + (2 * ((2*W) / (1))))) + ((((1) / 2) - floor((1) / 2) != 0) ? ((2 * ((400n > (((400n) - 200n) + 400n)) ? 400n : (((400n) - 200n) + 400n))) + (2 * ((2*W) / (1)))) : 0)) / 1 \
m=(1)*(1)
NM0 (net12 vip net11 0) nmos1 w=((W) / (1)) l=L as=(((W) / (1)) < 599.5n) ? (((((200n > (((400n) - 200n) + 400n)) ? 200n : (((400n) - 200n) + 400n)) * 600n) + (((W) / (1)) * 200n)) + (floor(((1) - 1) / 2.0) * (((((400n) - 200n) + 400n) * 600n) + (((W) / (1)) * 400n))) + ((((1) / 2) - floor((1) / 2) == 0) ? ((((200n > (((400n) - 200n) + 400n)) ? 200n : (((400n) - 200n) + 400n)) * 600n) + (((W) / (1)) * 200n)) : 0)) / 1 : ((((400n > (((400n) - 200n) + 400n)) ? 400n : (((400n) - 200n) + 400n)) * ((W) / (1))) + (floor(((1) - 1) / 2.0) * ((((400n) - 200n) + 400n) * ((W) / (1)))) + ((((1) / 2) - floor((1) / 2) == 0) ? (((400n > (((400n) - 200n) + 400n)) ? 400n : (((400n) - 200n) + 400n)) * ((W) / (1))) : 0)) / 1 \
m=(1)*(1)
NM1 (vo vim net11 0) nmos1 w=((W) / (1)) l=L as=(((W) / (1)) < 599.5n) ? (((((200n > (((400n) - 200n) + 400n)) ? 200n : (((400n) - 200n) + 400n)) * 600n) + (((W) / (1)) * 200n)) + (floor(((1) - 1) / 2.0) * (((((400n) - 200n) + 400n) * 600n) + (((W) / (1)) * 400n))) + ((((1) / 2) - floor((1) / 2) == 0) ? ((((200n > (((400n) - 200n) + 400n)) ? 200n : (((400n) - 200n) + 400n)) * 600n) + (((W) / (1)) * 200n)) : 0)) / 1 : ((((400n > (((400n) - 200n) + 400n)) ? 400n : (((400n) - 200n) + 400n)) * ((W) / (1))) + (floor(((1) - 1) / 2.0) * ((((400n) - 200n) + 400n) * ((W) / (1)))) + ((((1) / 2) - floor((1) / 2) == 0) ? (((400n > (((400n) - 200n) + 400n)) ? 400n : (((400n) - 200n) + 400n)) * ((W) / (1))) : 0)) / 1 \
m=(1)*(1)
PM0 (vo net12 vdd vdd) pmos1 w=((2*W) / (2)) l=L as=(((2*W) / (2)) < 599.5n) ? (((((200n > (((400n) - 200n) + 400n)) ? 200n : (((400n) - 200n) + 400n)) * 600n) + (((2*W) / (2)) * 200n)) + (floor(((2) - 1) / 2.0) * (((((400n) - 200n) + 400n) * 600n) + (((2*W) / (2)) * 400n))) + ((((2) / 2) - floor((2) / 2) == 0) ? ((((200n > (((400n) - 200n) + 400n)) ? 200n : (((400n) - 200n) + 400n)) * 600n) + (((2*W) / (2)) * 200n)) : 0)) / 2 : ((((400n > (((400n) - 200n) + 400n)) ? 400n : (((400n) - 200n) + 400n)) * ((2*W) / (2))) + (floor(((2) - 1) / 2.0) * ((((400n) - 200n) + 400n) * ((2*W) / (2)))) + ((((2) / 2) - floor((2) / 2) == 0) ? (((400n > (((400n) - 200n) + 400n)) ? 400n : (((400n) - 200n) + 400n)) * ((2*W) / (2))) : 0)) / 2 \
ad=(((2*W) / (2)) < 599.5n) ? ((floor((2) / 2.0) * (((((400n) - 200n) + 400n) * 600n) + (((2*W) / (2)) * 400n))) + ((((2) / 2) - floor((2) / 2) != 0) ? ((((200n > (((400n) - 200n) + 400n)) ? 200n : (((400n) - 200n) + 400n)) * 600n) + (((2*W) / (2)) * 200n)) : 0)) / 2 : ((floor((2) / 2.0) * ((((400n) - 200n) + 400n) * ((2*W) / (2)))) + ((((2) / 2) - floor((2) / 2) != 0) ? (((400n > (((400n) - 200n) + 400n)) ? 400n : (((400n) - 200n) + 400n)) * ((2*W) / (2))) : 0)) / 2 \
ps=(((2*W) / (2)) < 599.5n) ? (((2 * ((200n > (((400n) - 200n) + 400n)) ? 200n : (((400n) - 200n) + 400n))) + 1.6u) + (floor(((2) - 1) / 2.0) * ((2 * (((400n) - 200n) + 400n)) + 2u)) + ((((2) / 2) - floor((2) / 2) == 0) ? ((2 * ((200n > (((400n) - 200n) + 400n)) ? 200n : (((400n) - 200n) + 400n))) + 1.6u) : 0)) / 2 : (((2 * ((400n > (((400n) - 200n) + 400n)) ? 400n : (((400n) - 200n) + 400n))) + (2 * ((2*W) / (2)))) + (floor(((2) - 1) / 2.0) * ((2 * (((400n) - 200n) + 400n)) + (2 * ((2*W) / (2))))) + ((((2) / 2) - floor((2) / 2) == 0) ? ((2 * ((400n > (((400n) - 200n) + 400n)) ? 400n : (((400n) - 200n) + 400n))) + (2 * ((2*W) / (2)))) : 0)) / 2 \
pd=(((2*W) / (2)) < 599.5n) ? ((floor((2) / 2.0) * ((2 * (((400n) - 200n) + 400n)) + 2u)) + ((((2) / 2) - floor((2) / 2) != 0) ? ((2 * ((200n > (((400n) - 200n) + 400n)) ? 200n : (((400n) - 200n) + 400n))) + 1.6u) : 0)) / 2 : ((floor((2) / 2.0) * ((2 * (((400n) - 200n) + 400n)) + (2 * ((2*W) / (2))))) + ((((2) / 2) - floor((2) / 2) != 0) ? ((2 * ((400n > (((400n) - 200n) + 400n)) ? 400n : (((400n) - 200n) + 400n))) + (2 * ((2*W) / (2)))) : 0)) / 2 \
m=(1)*(2)
PM1 (net12 net12 vdd vdd) pmos1 w=((2*W) / (2)) l=L as=(((2*W) / (2)) < 599.5n) ? (((((200n > (((400n) - 200n) + 400n)) ? 200n : (((400n) - 200n) + 400n)) * 600n) + (((2*W) / (2)) * 200n)) + (floor(((2) - 1) / 2.0) * (((((400n) - 200n) + 400n) * 600n) + (((2*W) / (2)) * 400n))) + ((((2) / 2) - floor((2) / 2) == 0) ? ((((200n > (((400n) - 200n) + 400n)) ? 200n : (((400n) - 200n) + 400n)) * 600n) + (((2*W) / (2)) * 200n)) : 0)) / 2 : ((((400n > (((400n) - 200n) + 400n)) ? 400n : (((400n) - 200n) + 400n)) * ((2*W) / (2))) + (floor(((2) - 1) / 2.0) * ((((400n) - 200n) + 400n) * ((2*W) / (2)))) + ((((2) / 2) - floor((2) / 2) == 0) ? (((400n > (((400n) - 200n) + 400n)) ? 400n : (((400n) - 200n) + 400n)) * ((2*W) / (2))) : 0)) / 2 \
m=(1)*(2)
E0 (vim net03 vip net03) vcvs gain=-1.0
V1 (vip net03) vsource mag=1 type=sine ampl=1m freq=1K
I5 (vdd net5) isource dc=I type=dc
V3 (net03 0) vsource dc=900.0m type=dc
V0 (vdd 0) vsource dc=1.8 type=dc
No.The netlist
What do you want to show ?("/opt/cad/cad/FOUNDRY/analog/180nm/models/spectre/gpdk.scs" "stat")
modelFile(
desVar( "W" "" )
desVar( "L" "" )
desVar( "I" "" )
envOption(
temp( 27 )
paramRun()
close(prt);
It is possible.Is it possible to do parametric analysis for three different variables at a time?
I can not understand what you want to mean at all.I'm new to Cadence
I can not understand what you want to mean at all.I have to write code for Nelder-Mead method in Ocean.
I answered in #8 clearly.--------------------------------------
can you tell me what's wrong in this code?
// Generated for: spectre
// Generated on: Jun 21 15:06:12 2017
// Design library name: Kiran_OTA
// Design cell name: diff_amp
// Design view name: schematic
simulator lang=spectre
global 0
global 0
parameters W L I
include "/opt/cad/cad/FOUNDRY/analog/180nm/models/spectre/gpdk.scs" section=stat
m=(1)*(1)
m=(1)*(1)
m=(1)*(1)
m=(1)*(1)
m=(1)*(2)
m=(1)*(2)
simulatorOptions options reltol=1e-3 vabstol=1e-6 iabstol=1e-12 temp=27 \
tnom=27 scalem=1.0 scale=1.0 gmin=1e-12 rforce=1 maxnotes=5 maxwarns=5 \
digits=5 cols=80 pivrel=1e-3 sensfile="../psf/sens.output" \
checklimitdest=psf
dcOp dc write="spectre.dc" maxiters=150 maxsteps=10000 annotate=status
dcOpInfo info what=oppoint where=rawfile
ac ac start=10 stop=100G annotate=status
modelParameter info what=models where=rawfile
element info what=inst where=rawfile
outputParameter info what=output where=rawfile
designParamVals info what=parameters where=rawfile
primitives info what=primitives where=rawfile
subckts info what=subckts where=rawfile
saveOptions options save=allpub
