ocean script for 65nm ST
nasirq
Newbie level 3
Newbie level 3
I am trying to run ocean script using 65nm STmicro process. It seems to run fine till it encounters the simulation part and there it gives the following error
ERROR (SFE-675):
"/cadtools/cadence/PSG/DesignKits/STM/cmos065_522DK_cmos065lpgp_RF_7m4x0y2z_2V51V8_5.2.2/DATA/SPECTRE/CORNERS/common_poly.scs"
8: Illegal library definition found in netlist
which seems to be not able to read the model files.
Had anyone worked on the ocean scripts for 65nm STmicro process?
Just a guess: Does your ocean script (before calling the .scs file) or your spectre .scs file itself contain the command "simulator lang=spectre" ? It should.
I do have this line which tells that it is a spectre simulation taken from the save script file from ADE
simulator( 'spectre )
