Jun 22, 2012 #1 S surreyian Member level 3 Joined Feb 10, 2006 Messages 63 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 1,796 Hello, How can I run corner with Ocean? I saved a copy of ocean script to run paramateric analysis. How can I include corners to it. Anyone can help me out?
Jun 22, 2012 #2 A analogLow Member level 4 Joined Nov 18, 2010 Messages 68 Helped 15 Reputation 30 Reaction score 12 Trophy points 1,288 Location Earth Activity points 1,785 type into virtuoso shell: UartCornerSetup (or UartSetupCorners or UartSetupCorner) It is one of those ...just not in front of my workstation now and cant remember exactly. analogLow surreyian said: Hello, How can I run corner with Ocean? I saved a copy of ocean script to run paramateric analysis. How can I include corners to it. Anyone can help me out? Click to expand...
Jun 25, 2012 #3 A analogLow Member level 4 Joined Nov 18, 2010 Messages 68 Helped 15 Reputation 30 Reaction score 12 Trophy points 1,288 Location Earth Activity points 1,785 I confirmed that is is: UartCornerSetup
Jun 26, 2012 #4 S surreyian Member level 3 Joined Feb 10, 2006 Messages 63 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 1,796 what does that do? it says undefined variable - UartCornerSetup
Jun 26, 2012 #5 A analogLow Member level 4 Joined Nov 18, 2010 Messages 68 Helped 15 Reputation 30 Reaction score 12 Trophy points 1,288 Location Earth Activity points 1,785 surreyian said: what does that do? it says undefined variable - UartCornerSetup Click to expand... That should pull up the window that allows you to select the process corner (e.g. TT,FF,SS,FS, or SF). Also, you can choose local variations there. Make sure to type "UartCornerSetup" into your Command Interpreter Window in Virtuoso. What process are you using?
