Oct 18, 2007 #1 J jc2 Member level 3 Joined Mar 5, 2005 Messages 64 Helped 3 Reputation 6 Reaction score 1 Trophy points 1,288 Activity points 1,793 I want a sweep with a DC level for testing the PSRR of my reference source. How could I obtain that sweep with the DC level if I have a sweep generator which doesn't have the offset option?. Could I plug a supply source to the sweep generator? Do I need some capacitor-resistor configuration for coupling the sweep generator with the supply source? A draw would be nice. Thanks
Oct 19, 2007 #2 V vicky Full Member level 4 Joined Aug 11, 2004 Messages 235 Helped 23 Reputation 46 Reaction score 4 Trophy points 1,298 Activity points 2,404 Re: Sweep generator hi dear, you must have to create a supply that control your sweep generator wopuld you like to tell me tyour sweep generator configuration
Oct 30, 2007 #3 B BoBtHePlUmBeR Junior Member level 2 Joined Oct 23, 2007 Messages 23 Helped 8 Reputation 16 Reaction score 0 Trophy points 1,281 Activity points 1,465 Sweep generator Hi jc2, you might need to use an op amp and a few resistors in the summing amplifier configuration see: http://www.ecircuitcenter.com/Circuits/opsum/opsum.htm
Oct 31, 2007 #4 K krishna_1980 Junior Member level 3 Joined Jan 4, 2006 Messages 25 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,457 Sweep generator plz check with this Added after 17 seconds: http://www.ecircuitcenter.com/Circuits/opsum/opsum.htm
