chromatik
Member level 4
- Joined
- Aug 15, 2006
- Messages
- 78
- Helped
- 2
- Reputation
- 4
- Reaction score
- 4
- Trophy points
- 1,288
- Location
- Switzerland
- Activity points
- 1,882
Hello all,
I am spending some times trying to obtain a spice/spectre model from a Momentum simulation.
I already obtained a model but I'm not sure this will be the correct way.
Let me describe how I'm doing:
- first, launch the ADS Momentum simulation
- create a model of my simulation
- back to ADS circuit environment I insert the component
- then after, run the Spice Model Generator, broadband
- specify the file type: dataset
- specify the file type: spectre
- run the conversion
I got a scs file, as planned, but I'm not sure this is the correct way, and if it's the good result.
In fact -and that was my fist objective- I'd like to obtain a file containing the s-parameters results form the Momentum simulation, as a blackbox.
But even with the helpfile, it's not that clear.
Any help would be very useful.
Thanks a lot, in advance !
Regards
Regards
