anjukeshari
Newbie level 5
hi,
i am designing a smart cane that is used to detect the obstacle using ultrasonic sensor.
the ultrasonic transmitter uses 40 Khz frequency pulses with pk-pk voltage nearly 18 volts. the circuit i have uses nand gate, transistor and then not gate amplify the pulses coming from 555 timer. what can i use instead of parallel not gate to amplify the pulses of 40 khz and 9V to 18V?
