Object intersect in HFSS
Hello
here is another problem
both of them have the same material but I want to have a good connection between two pec object (as you see in QFH antenna
) but it seems they cause "intersect " error. how can I model this junction without any error?
if they are intersecting and of same material then you may unite them or you should remove the intersection between them
