Dec 24, 2010 #1 S sharjeel1 Newbie level 3 Joined Mar 13, 2007 Messages 4 Helped 2 Reputation 2 Reaction score 1 Trophy points 1,283 Activity points 1,301 i am having problem with "to_integer",it says "No feasible entries for subprogram to_integer" what should i do? does any 1 hav link of numeric_std???
Dec 24, 2010 #2 alexan_e Administrator Joined Mar 16, 2008 Messages 11,888 Helped 2,021 Reputation 4,158 Reaction score 2,031 Trophy points 1,393 Location Greece Activity points 64,371 The library is included in your software but here is a link **broken link removed** I think it would be better is you post your code, or the part that creates the error including the types of the signals used. Also make sure that you are not using IEEE.STD_LOGIC_ARITH.ALL; IEEE.STD_LOGIC_UNSIGNED.ALL; Alex Last edited: Dec 24, 2010
Dec 24, 2010 #3 T TrickyDicky Advanced Member level 7 Joined Jun 7, 2010 Messages 7,110 Helped 2,081 Reputation 4,181 Reaction score 2,047 Trophy points 1,393 Activity points 39,769 you're probably trying to convert a type other than signed or unsigned.
