You should educate yourself on how a general purpose FIFO is implemented in modern FPGAs.
It isn't a hardened silicone block in the FPGA. Therefore, it shouldn't be considered as a resource or counted as such.
Instead, a FIFO is (usually) built using block RAMs. These block RAMs are indeed a hardened silicone block inside an FPGA that can be counted.
So thinking in the correct direction to answer your question will involved calculating the RAM memory resources required with implementing each FIFO and adding all the results.
