Notch filter using negative resitance
stenzer
Advanced Member level 3
I'm trying to realize a "narrow" notch filter which should operate in the lower MHz - range. Therefore I need a large inductance. This results in a low Q.
I read that it is possible to enhance the Q by adding a negative resistance with a transistor.
Can anyone tell my how to design such a filter?
Thanks
vfone
Advanced Member level 6
Yes is possible to do this mechanism to enhance the Q of the resonator. The circuit is basically a feedback amplifier with variable gain.
BradtheRad
Super Moderator
Staff member
Advanced Member level 7
Minneapolis, Minnesota, USA
If we take a simple LC tank as a notch filter...
Q is a result of L:C ratio interacting with neighboring impedances.
The available current has a lot to do with determining which LC ratio will be most suitable.
stenzer
thank you for your replies. I tried to realize the negative resistance with a current sink, by changing its Drain voltage. Unfortunately it doesn't work well. Is there a better (and simple) way do enhance the Q?
BR
