xpress_embedo
- Joined
- Jul 5, 2011
- Messages
- 1,154
- Helped
- 161
- Reputation
- 396
- Reaction score
- 189
- Trophy points
- 1,353
- Location
- India
- Activity points
- 10,591
Hello!! Everyone i am working on LPC1343 Micro-controller and wants to interface RTCC PCF8523 with LPC1343.
I write code for I2C protocol but its not working.
The problem is found when i send repeated start from master (LPC1343), the status for this must be 0x10 while i am getting 0x28 every time.
I am attaching my code in the zip file available below.
View attachment PCF8523_RTCC.zip
The functions used for I2C Protocol are as follow:-
In function Read from RTCC (given below)
As i dont have debugger i checked the content of Status Bytes on UART, i found that for I2c_Start, the status byte contains 0x08 when sending rtcc address i am getting status = 0x18 and then after sending the address from where i have to read i am getting status = 0x28 which is correct.
Upto this point i am getting valid status responses, but after sending Repeated Start i am getting 0x28 each and every time continuously.
Can anyone please help me to solve this issue.
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 #include "LPC13xx.h" #include "I2C.h" #include "UART.h" void I2C_Init(unsigned char Mode) { LPC_SYSCON->PRESETCTRL |= (1<<1); //De-Asserts Reset Signal to I2C LPC_SYSCON->SYSAHBCLKCTRL |= (1<<5); //Enable I2C Clock LPC_IOCON->PIO0_4 &= ~0x3F; LPC_IOCON->PIO0_4 |= 0x01; //SCL LPC_IOCON->PIO0_5 &= ~0x3F; LPC_IOCON->PIO0_5 |= 0x01; //SDA if(Mode == I2C_SPEED_400) { LPC_I2C->SCLH = 90; //I2PCLK is 72MHz LPC_I2C->SCLL = 90; //I2PCLK is 72MHz } else if(Mode == I2C_SPEED_100) { LPC_I2C->SCLH = 360; //I2PCLK is 72MHz LPC_I2C->SCLL = 360; //I2PCLK is 72MHz } LPC_I2C->CONCLR = 0xFF; //Clear All Flags LPC_I2C->CONSET = (1<<6); //I2C Interface Enable } void I2C_Start(void) { LPC_I2C->CONSET |= 0x20; //Set the Start Bit while(LPC_I2C->STAT!=0x08); //Wait for the Status Bit } void I2C_Restart(void) { LPC_I2C->CONSET |= 0x20; //Set the Start Bit while(LPC_I2C->STAT!=0x10); //Wait for the Status Bit } void I2C_Stop(void) { LPC_I2C->CONSET |= 0x14; //Stop I2C LPC_I2C->CONCLR = 0x08; } void I2C_Write(unsigned char data,unsigned char status) { LPC_I2C->DAT = data; LPC_I2C->CONCLR = 0X28; //Clear Start Flag and SI Interrupt while(LPC_I2C->STAT!=status); //Wait for the Status Byte } unsigned char I2C_Read(void) { LPC_I2C->CONCLR = 0X28; while (LPC_I2C->STAT!=0x50); //Wait for Status Set - 0x50 return(LPC_I2C->DAT); }
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 unsigned char PCF8523_Read(unsigned char Address) { unsigned char temp; I2C_Start(); UART_Write('1'); I2C_Write(PC8523_ADDRESS,0x18); UART_Write('2'); I2C_Write(Address,0x28); UART_Write('3'); I2C_Restart(); UART_Write('4'); I2C_Write(PC8523_ADDRESS+1,0x40); UART_Write('5'); temp = I2C_Read(); UART_Write('6'); I2C_Stop(); UART_Write('7'); return temp; }
