Noob with PIC12F683. work with Vcc from PICKIR2, always on with external power.
lachmannmarcel
Junior Member level 3
Romania
Hi.
I start playing with PIC12F683.
With my code (see below) when VCC is coming from PICKIT2 its wotking fine.
When my power come from external 12v my led is always ON.
Please advice. What is wrong in my schematics.
*   Processor:     12F683                                               *
*   Pin assignments:                                                    *
*   GP0 - ISCPDATA														*
*   GP1 - buton															*
*   GP2 - PWM															*
*   GP3 - MCLR															*
*   GP4 - Test Led		       	                                        *
*   GP5 - Touch	with GP1 as load	       								*							       	                                        		*
#include <htc.h>
/***** CONFIGURATION *****/
__CONFIG(
	FCMEN_OFF &  // Fail Clock Monitor Enable
	IESO_OFF &  // Internal External Switch Over
	BOREN_OFF &  // Brown-out detect modes
	CP_OFF &  // Protection of data block
	CPD_OFF &  // Protection of program code
	MCLRE_OFF &  // Master clear reset
	PWRTE_OFF &  // Power up timer enable
	WDTE_OFF &  // Watchdog timer enable
	FOSC_INTOSCIO  // Oscillator configurations: internal
// Define oscillator frequency
#define _XTAL_FREQ 8000000
void main(void)
	OSCCON = 0b01110001;	// 8Mhz INT OSC
	// Set up the PIC12F683 IO pins
	TRISIO = 0b00000000;	// Set all IO pins to output
	ANSEL  = 0b00000000;	// Disable analogue inputs
	//ADCON0=
	GPIO   = 0b00000000;	// Set all pins to zero
	OPTION_REG = 0b00000000;	// Set the option register (page 12 of DS)
	WPU    = 0b00000000;	// Set weak pull-up off on all pins
	CMCON0 = 7;		// Disable Comparator on 12F683
	while(1)
		GP4=1; __delay_ms(1000);  GP4=0;__delay_ms(1000);
This code should work.
while(1)
	{       GPIO   = 0b00000000;
while(1)
I know that my English is not so good, but this code work when Vcc is from Pickit2. Where i remove my Pickit2 and power come from external plug(12v) led is always ON.
Seems like a hardware problem, have you checked the 12v connections on your hardware? And isn't the test LED in your schematic reversed?
Yes 12 V is ok. In hardware my led is conected ok.
Strange thing: i put MCLR la ground(i disconected the diode 1n4148) and with external power is working. I dont understand .....
