none configuration word in the hex file PIC16F887
Wajiduddaim
Junior Member level 1
darbar-e-Sadria
Hi
i m new and basic user
using PIC16F887, and i m facing the problem before writing it, the message appears
"Warning some configuration words not in hex file, Please Set it after the loading"
what dose its mean?
but its working fine in " Proteus ISIS 7 Professional "
my code is
unsigned char temp_value = 0;
unsigned char old_value = 0;
sbit LED at RA1_bit;
void main()
  ANSEL  = 0x01;              // Configure AN0 pin as analog
  TRISA  = 0xFD;              // one pic for putput
  ANSELH = 0;                 // Configure other AN pins as digital I/O
  UART1_Init(9600);              // Initialize UART module at 9600 bps
  Delay_ms(100);                 // Wait for UART module to stabilize
while (1)
      {                    // Endless loop
         Delay_ms(500);                 // Wait aprox 50% duty cycle, jst blink LED
         LED = !LED  ;
         temp_value = ADC_Read(0);   // Get 10-bit results of AD conversion
         if(old_value != temp_value)
             old_value = temp_value;
             UART1_Write(temp_value);       //   and send data via UART
the pin 13 and 14 for crystal ???
if i use external crystal 11.0592MHz, can i connect it with directly with Micro-controller at pic 13 and 14, i mean without Initializing in code because these pins are also I/O pins
i m using " mikroC PRO for PIC V1.65 "
Hi
what dose its mean?
my code is
void main()
while (1)
      {                    // Endless loop
         LED = !LED  ;
Hi
what dose its mean?
my code is
void main()
while (1)
      {                    // Endless loop
         LED = !LED  ;
Hi
what dose its mean?
my code is
void main()
while (1)
      {                    // Endless loop
         LED = !LED  ;
Pic can also be run on internal clock then these two pins may be used as IO, you need to program HS fuse for using crystal, as I am also beginner hence some questions I can't answer, but I think you need to program fuse bits to get rid of configuration word message.
