Noise Simulation using cadence
AMSA84
Advanced Member level 2
Iberian Peninsula
Hi everyone,
I am designing an offset cancellation circuit and I want to do a noise simulation. My goal is to do the simulation using the circuit without the offset cancellation technique and then using the same topology using the offset cancellation technique and compare both noises.
I have tried the noise analysis, but I don't know if this analysis takes into account the switching behaviour/nature of the cancellation circuit since the noise analysis is just a simple frequency sweep across the desired frequency range.
Does anyone knows how to do it?
Regards.
Since you are saying its a switching technique based offset cancellation. Your should be using periodic steady state methods. PSS/PNOISE will help you,
