hi everybody,
I am using signal processing blocks in matlab- R(2010'a) for noise cancellation using adaptive filters. Here, i am analysing LMS, N-lms, RLS algorithms. In N-lms i am not able to clear error. Please could some experts can help me to solve out this problem. I am ready to load my designed model here, if you need.
hi,
Thanks for your reply. I am getting error like, model supported with Embedded IDE ccsV4.1.
Before that, i want to know, how will i interface any simulink model with c6000 processors via ccs? i am using simulink -7.5 with ccs 3.1. basically, what version i need?
you will always get error if you are directly using simulink blocks you have to write codes for the whole algorithm
For example , For LMS Noise cancellation MATLAB codes are as follows:
close all;
clear all;clc;
Now you can just convert it into c code and using ccstudio you can cancel Noise.
If you are not getting correct output than there is possibility that your kit ROM burner is not properly working. You can get this ROM Burner from Texas Websites.
