in cadence i hav simulated the circuit and tried to plot node transient response,but it doesn't
showing the plot, a warning (no "VT" data for node "/netxxx" ) is displayed in the icfb window
can anyone help me how to eliminate the warning " no VT data for node xxx in cadence".
The CDF definition of the instance/PDK does not have termMapping field defined. The fix needs to be done by Engineer who have write permission to the PDK files (like PDK CAD engineers)
check that you have an "amap" folder in your ../netlist folder. this should be generated by ADE when netlisting. also you can try modifying your expression to v("netxxx" ?result "tran"). Notice no "/" before netname.
