no switching from bank 1 to bank 0
newbie111
Member level 2
h.k
[#include <p16F690.inc>
__config (_INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _BOR_OFF & _IESO_OFF & _FCMEN_OFF)
myPortC equ 0x07
org 0x000
start movlw 0x00
tris myPortC
movlw b'1111'
movwf myPortC
circle goto circle
end]
I tried the code and it worked
my q is how come we do not need to go from bank 1 to bank 0 for setting?
Thanks[/code]
Afraid you have missed the point about these registers.
The TRIS instruction sets the direction of the Port , Input or Output.
The PORT instruction moves the data To or From the i/o pins
The other thing that confuses a lot of beginners, its that when first powered on, the default settings are that many of the i/o pins are set to Analogue mode so you must first turn the ones you want to Digital by means of the ADCON1 instruction.
Download the Pickit2 Starter Kit Lessons at the bottom of this page. It is a beginners practical programming tutorial for the 16F690 from Microchip, it demostarates these points and should help get you going.
    newbie111
