I have a intermixed input signal of 100 KHz (Ican reduce it to 50KHz if required) pulsed signal @5V and a very low frequency signal. In mode one, the input signal is high frequency; in mode two, it is near DC below 5V. I need an exact copy of this signal. I tried to use TL3472 in unity gain voltage follower but the output has amplitude loss.
What do you suggest me? I have OPA1662 and LM358 in my stock currently. I can buy another one if required.
"no phase delay" is not possible.
Better give a more useful specification.
amplitude loss with DC input?
--> what is your circuit? What are your test conditions? What is your measuremnt equippment? What are the exact test results?
If you stick with "no, no, 1.0000..." as requirements then
the problem becomes very easy - you can just quit now.
The highest closed loop BW is likely to be found in CFAs
but these don't always have the best input offset, and
they want current. Not a problem in 50-ohm systems
where they are often used, but not good for a high-Z
or variable-Z (such as a CMOS mux across temp & supply)
signal source.
