No matching overload in VHDL
bsbs
Junior Member level 2
Im getting :32:14:32:24|No matching overload for "<" error for the following code
Code VHDL - [expand]
8
9
10
11
12
13
14
15
Process (clk, RST)
BEGIN
     IF RST = '0' THEN
        acc <= (Others => '0') ;
     ELSIF (Clk = '1' and Clk'event)  THEN
        If acc = max THEN
           acc <= (others => '0') ;
        ELSE
          acc <= acc + '1' ;
          output <= acc < input;
        END IF ;
     END IF ;
END PROCESS ;
Im using std_logic_signed .
Re: No matching overload error
acc < input
returns a boolean, not a std_logic. Unless output is declared as a boolean, you have to write it like this:
if acc < input then
  output <= '1';
else
  output <= '0';
end if;
or if you have a VHDL 2008 compliant compiler (very unlikely) you can write:
output <= '1' when (acc < input) else '0';
That line: "output<=acc<input" doesn't look right. What is the type of output, input? Are you trying to set output to 1 if acc is less than input? If so, try using an if statement.
        If acc< input then
           output<='1';
        else
          output<='0';
        end if;
thank you. Can you tell me exactly what are the merits of VHDL over verilog (not text book answers) application wise
They are both different. Some love VHDL, some love verilog. But they both do the same things. You need to chose which one you prefer.
