NMEA protocol GPS help
eng_boody
Member level 3
Member level 3
Hi I have got Arduino ITEAD GPS shield which Uses NMEA protocol....and UART to transfer a string of data, what are the buffer size i need for incoming bit stream to get full data ...thanks
It depends largely on the specific NMEA sentences your particular device outputs and required for your application.
The following reference outlines the format of each NMEA sentence and can be used to determine the required buffer size required:
GPS - NMEA sentence information
You should also refer to the specific GPS modules documentation.
BigDog
