library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_SIGNED.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
entity UARTtx is
Generic (
CLK_FREKANS : integer := 100000000;
BAUDRATE : integer := 100000000
Port (
i_clk : in std_logic;
i_reset : in std_logic;
i_data_tx :in std_logic_vector(7 downto 0);
i_tx_start : in std_logic;
o_tx_out :out std_logic;
LED :out std_logic_vector(7 downto 0)
end UARTtx;
architecture Behavioral of UARTtx is
constant CLK_BIT : integer := (CLK_FREKANS / BAUDRATE) + 1;
type t_UART_tx is (IDLE, START, SENT, DONE, OK);
signal r_UART_tx : t_UART_tx := IDLE;
signal r_clk_cnt : integer range 0 to CLK_BIT - 1 := 0;
signal r_data_indis : integer range 0 to 7 :=0;
signal r_data : std_logic_vector(7 downto 0) := (others=>'0');
signal r_tx : std_logic:= '1';
signal r_tx_tamam : std_logic := '0';
signal temp : std_logic;
begin
o_tx_out <= r_tx;
LED <= r_data;
process(i_clk,i_reset) is
begin
if i_reset = '1' then
r_UART_tx <= IDLE;
r_clk_cnt <= 0;
r_data_indis<= 0;
r_data <= (others => '0');
r_tx <= '1';
r_tx_tamam <= '0';
elsif rising_edge(i_Clk) then
temp <= i_tx_start;
r_tx_tamam <= '0';
case r_UART_tx is
when IDLE =>
r_tx <= '1';
r_data_indis<= 0;
if temp='0' and i_tx_start='1' then
r_data <= i_data_tx;
r_UART_tx <= START;
end if;
when START =>
if r_clk_cnt = CLK_BIT - 1 then
r_tx <= '0';
r_UART_tx <= SENT;
else
r_clk_cnt <= r_clk_cnt + 1;
end if;
when SENT =>
r_tx <= r_data(r_data_indis);
r_clk_cnt <= 0;
if r_data_indis = 7 then
r_data_indis<= 0;
r_UART_tx <= DONE;
else
r_data_indis <= r_data_indis +1;
end if;
else
end if;
when DONE =>
r_tx <= '1';
r_clk_cnt <= 0;
r_UART_tx <= OK;
else
end if;
when OK =>
r_tx <= '1';
r_tx_tamam <= '1';
r_UART_tx <= IDLE;
when others => NULL;
end case;
end if;
end process;
end Behavioral;
