Dear All,
I'm doing a project based on Nexys-2 FPGA board.
A sensor module and FT2232H USB module are connected to Pmod connectors of Nexys-2.
There are two modules in my FPGA design, one is sensor interface module, other is FT2232 module.
Sensor interface samples output of my sensor, and routes it to FT2232 module.
FT2232 module captures data and sends it to PC over USB.
While debugging my design with Chipscope, I have faced with an interesting issue.
While board is powered over USB port, I am observing my internal signals(FPGA internal signals - sensor module and FT2232H module port mapping signals, not output or input ports) and assume that have a value 0x55;
While board is powered with adapter, same internal signal value is 0x90 etc - something impossible. I mean, internal signal value is changed. However, it should be same. I also changed the jumpers.
Powering with adapter should give correct results however it is not. Because, sensor needs 400mA and it is dangerous to connect the board to USB.
How could it be? Any ideas, I freak out. 8-O
