S
saradilc
Hello everyone, I am a huge newbie to electronics but I'm quite captivated by it. I am trying to make a series circuit. I will try to describe it as best as I can and explain my dilemma.
I'm going to be using a 9V battery to power some LED lights. I am also using a toggle switch to turn the lights on/off, and a 3 position selector switch to choose which colour lights are on (red blue or green.)
These lights are being used to light up a momentary switch (arcade button), which is wired seperately as a guitar killswitch. When I push the momentary switch it grounds the guitar tone, but I would also like to wire the momentary switch to turn off the LEDs when pushed, to create a strobe effect when the killswitch is used.
The dilema is as follows: As far as I understand I would need a N.C switch to kill the lights. Although arcade buttons come with both N.O and N.C on some models, those models do not fit inside a guitar, so I had to buy a shorter one that is solely N.O
Could I wire the N.O momentary switch to somehow turn off the lights when held down?
Thank you for your time!
