sintox
Junior Member level 1
Hi all,
Sorry for asking the following dumb questions.
I have this loop in HFSS and I would like to connect that loop to 1Watt of power, then 2Watts, of a sinusoidal signal of 150 MHz.
I would like to find out the exact magnetic field (A/m) *AND* the received power at a very short distance around the loop.
A)
I've tried to set the loop to a current port of 1000mA. The question is: Can I assume the power is squared(1000mA) x port-impedance ?
B)
In the report, I selected near-field EfieldTheta and then EfieldPhi because I cannot find HfieldTheta or Phi anywhere. The question is: How do I get a table of the Hfield (magnetic) and then total EMfield (total E and H), in Watts, not A/m ?
Thank you so much.
ox
A)
B)
Thank you so much.
ox
