Pigi_102
Member level 2
Hi all,
after some succesful debugging session with the ICD2 clone, yesterday I got a relly strange problem.
I've attached the ICD2 to the computer and windows did not recognized it.
I' ve said " No Problem, I have to check if something has changed to the drivers" but it was all correct.
Then I've reflashed the 4550 as sometime the firmware get lost.
Same problem after the reprogramming phase.
I've checked if there were something wrong under the board as I didn't change nothing either on the board than on the XP.
Everything was ok.
What I've noticed is that the 4550 get really hot.
After several test in reflashing either the 4550 than the 877A it startsworking again without change on the board and on the windows side.
The really difference is that the board was really cold at the beginning of the tests as it was in the lab that has no way to get some hot air and the temperature was 8 degrees celsius.
Could it be a problem with crystal or similar at low temperatures ?
Wich are the things that I could check if the 4550 get hot ?
Pigi
Everything was ok.
Pigi
