Neon tube inverter, multiple tubes solution
zuzu
Member level 3
Member level 3
Hi friends,
I made myself a small UV exposure box and I'm very proud of results :) I used 4 small UV tubes, 7W each, originally designed for money check machines. Now they are powered each one on this own, by using ready made inverter PCBs found in kitchen / home appliances. Those are very cheap (and low quality) chinese, plastic soldered, I cannot know what electronics is inside before buy :)
Now the question is can I find some schematic to light all 8 tubes once? Maybe 10 tubes in future (5 top and 5 bottom)?
I found some simple inverter here
the question is can I use 5 tubes in series (or parallel?)
Any comments? Thanks very much.
