quantized
Member level 2
- Joined
- Jul 6, 2012
- Messages
- 51
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 1,288
- Activity points
- 1,887
Normally the P-substrate is tied to ground, which is also the lowest potential level found anywhere on the chip.
Negative substrate bias is the situation where the P-substrate is held at a potential lower than any other potential used on the chip (i.e. lower than the potential on any drain, source, gate, or metal layer).
Negative substrate bias has many beneficial effects relating to ESD and latchup, but I'm not concerned with those. What I am interested in is reducing junction capacitance. A negatively-biased substrate increases the size of the depletion region around all the NFET diode junctions, reducing the effective capacitance of these junctions. This should significantly improve switching speed and power consumption.
However there is a countervailing effect: biasing the substrate negative increases the threshhold voltage of the NFETs since it expands the depletion region around their channel. So the voltage at an NFET gate has to rise further before it begins conducting.
Have there been any studies of how these two effects play out against each other, and whether or not it's a net performance/power win to bias the substrate?
I've seen a lot of papers on ESD/latchup benefits, which are nice, but that's not really a major concern for me. I'm also not planning on using local charge pumps to drive the substrate negative locally -- if it's worth it I can afford to bring in a negative potential from off-chip via dedicated pads and metal (this is a low-current path, so the metal doesn't need to be too thick). Technically this "negative potential" will be true ground, i.e. the potential of the case to which the chip is bonded. The "real ground" supplied to the chip's power pads will be slightly positive, and the VDD supplied will be relative to this.
This is for a digital chip, but it's totally full-custom, so I figured posting here rather than the ASIC subforum would be the right approach… it's a digital chip, but this is an analog issue.
PS, I think it's hilarious that the forum's banner ads occasionally display ads for fashion modeling agencies. I guess the search term "modeling" has meaning outside of IC design!
