In IPC-7351 there are three solder fillets defined: toe, heel and side.
I naturally tend to believe the
width of solder fillets must be positive, since the physical quantity “length” is a scalar rather than a vector. I also find in an illustration in Kraig Mitzner’s
Complete PCB Design Using OrCAD Capture and PCB Editor, page 86, that all solder fillets are drawn positive.
However, what I do see in IPC-7351 table 3-2 to table 3-14 is that there are many
negative values for fillets. For example, all heel solder fillets for capacitors and resistors < 0603 are negative; in table 3-9, side fillets can be
either positive or negative.
I am really puzzled on the negative values found here: how can solder fillets, a concrete physical object which is formed of cooled solder, be of negative dimensions?
Matt
