Hello,
I did a stb simulation for a differential current input amplifier in a normal feedback setting.
I put the vsource in one of the input node of this amplifier, then run the stb simulation to check the openloop gain and phase for the stablity, but I get a negative loop gain( about -50dB in DC, then increse to 0dB with frequency increase) in one of the input. While do the same simulation for another input , get the normal possitive DB gain ( about 50dB).
but the difference for these two input loop gain should only have the 180 deg phase differense, right? why their gain have the + - difference? It tells that one of the loop is not amplifier signal but attenuate it, why this is happen?
Thank you very much !!
